5/28/2017 8:21 AM | |
Posts: 1529 Rating:
Download Sizer. It will help you select all of the bits needed for your motor and drive combination. https://support.industry.siemens.com/cs/document/54992004/sizer-for-siemens-drives?dti=0&lc=en-WW |
5/29/2017 2:04 PM | |
Joined: 10/11/2006 Last visit: 9/15/2025 Posts: 6039 Rating:
Hello aliman, for checking the cable connectors you can use the overview in the catalog D21.4, pg. 12/33: Concerning the motor side connector, you can find the used connector article numbers in the 1FW6 configuration manual, on pg. 47: In case you have a customer specific motor, please contact your local Siemens partner for this issue: I cannot reproduce the same cable configuration in SIZER as you described. In case you need more help here, please provide the motor and module article numbers. |
With best regards, |
