(0)| 4/26/2016 11:24 AM | |
Posts: 8092 Rating:
Hello, Servo motors are very special motors & repairs/servicing of these motors to be carried out at OEM, in your case at Siemens. Are you sure it is only encoder alignment problem? Is encoder OK? How you checked encoder? Is encoder cable OK? Why the motor winding is burnt? Because of overloading or coolant entry? Servo motors are very well protected from drive. So please check if there is any problem at LT motor module or at control card. However, please read this post, which will give you idea about encoder alignment.
