(0)| 11/15/2008 10:09 AM | |
Posts: 10 Rating:
I EXACTLY DON'T KNOW WHAT IS THE EXACT DIFFERENCE BETWEEN R-SYSTEM & H-SYSTEM |
| 11/17/2008 5:24 AM | |
Joined: 9/27/2006 Last visit: 1/13/2026 Posts: 12480 Rating:
Hello Rahul; You could look at that question from many sides, hardware, software, efficiency, power, pricing... But basically, the theoretical difference between H-systems and Software Redundancy is speed of recovery. H-systems (H- for High-Availability)are "hot-standby" topologies, where both S7-400H CPUs are synchronized at every scan using fiber-optic links, and the standby CPU can take over from the primary in a matter of microseconds. Software Redundancy is a "warm-standby" system; it does not synchronize the 2 CPUs completely (only the "redundant" part of the program) and recovery can take many seconds (depending on the network chosen for the redundancy support). You can look at the Simatic Controllers portal for a bit more information, or you can search on the forunm, both systems have been discusses often: https://www.automation.siemens.com/simatic/controller/html_76/benefits/benefits-availability.htm?HTTPS=REDIR Hope this helps, Daniel Chartier |
