(0)| 7/15/2025 7:31 AM | |
Joined: 8/5/2022 Last visit: 1/19/2026 Posts: 14 Rating:
Hi, We cannot get any communication with OPC UA, and we get BadCommunicationError from our UaExpert on another server. We've tried to update the certificates according to this article: https://support.industry.siemens.com/cs/de/en/view/109826043 Any suggestions to what might be the issue?
Last edited by: ostlar at: 07/15/2025 07:53:55Phrasing Last edited by: Moderator_Lan at: 07/15/2025 07:57:02link optimized Last edited by: ostlar at: 07/15/2025 10:42:43Corrected version |
| 7/15/2025 1:26 PM | |
Joined: 8/3/2009 Last visit: 1/21/2026 Posts: 16653 Rating:
Hello ostlar Check also this basic FAQ, perhaps some information helps: https://support.industry.siemens.com/cs/de/en/view/109763316 And do you have made a restart of the WIndows OS after all changes also with certificates? Do you have exported the CA from Certificate manager and then installed it to trusted cert stores in Windows? Bye Murof |
| 7/15/2025 1:42 PM | |
Thanks for the info!
Windows Firewall and Defender is deactivated. |
