(0)| 6/15/2015 3:14 PM | |
Joined: 1/28/2009 Last visit: 12/28/2025 Posts: 6889 Rating:
Hello, Central configuration requires installation of all I/Os in the central rack with a decentralized configuration, you can install I/O modules in vicinity of machine sections. for central configuration,it is good for small machines with limited number of I/Os while decentralized configuration saves wiring cost and makes the whole machine structure easier to understand but is vulnerable to physical constraints of network cables,noise and data corruption(frame loss). Search the net for more relative information. decentralized automation networks versus centralized I hope this helps, hdhosseini |
| 6/22/2015 10:46 AM | |
Posts: 125 Rating:
Hi, I go through this link but did not get clear idea. Please, will you explain same for simatic devicess. Thank you, |
| 6/22/2015 2:10 PM | |
Posts: 125 Rating:
Hi, Thanks. Please find in the attachment. In this case Rack-0 is central rack & Rack-1 is Expansion rack. is it right? Thank You, |
