2/24/2016 6:53 AM | |
Joined: 4/23/2010 Last visit: 11/23/2024 Posts: 8092 Rating:
Have you checked the LED status on panel? You mentioned drive is controlled by PLC. After factory setting you want to test it on DI i.e. terminal strip. Have you checked the setting of DIP switch on drive? Please refer the attached sheet for more information. AttachmentMM440 factory setting.pdf (574 Downloads) |
4/20/2016 2:03 PM |
Joined: 10/10/2010 Last visit: 7/5/2025 Posts: 309 Rating:
try to check the drive alarm via network by means of status word monitoring |
12/19/2017 3:16 PM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8171 Rating:
New question published by hschavda75 is split to a separate thread with the subject "P----" fault coming in MM440 drive . Best regards |
