(0)| 9/26/2008 11:35 AM | |
Posts: 133 Rating:
Hi Behzad You cannot use protool to program those Panels. You will need WinCC Flexible to program these Panels. Cheerz AttachmentWinCC Flex.pdf (611 Downloads) |
| 9/26/2008 11:38 AM | |
Posts: 133 Rating:
Oh sorry if you need to order it WINCC FLEXIBLE 2008 COMPACT - STANDARD Part Number : 6AV6612-2BC01-3AD5
| 9/29/2008 10:08 AM | |
Joined: 4/24/2006 Last visit: 12/24/2025 Posts: 9097 Rating:
Dear behzad5555, Please have a look here: http://support.automation.siemens.com/WW/view/en/29735640 Mind point 5, it is mentioning the order data of WinCC flexible 2008. See the special offer when you have Protool. @Bilal Moolla, the order number you mentioned is a Powerpack of WinCC flexible Compact to WinCC flexible Standard. (It means one should have WinCC flexible Compact to upgrade to WinCC flexible Standard.) Best regards, Wizard |
Last edited by: Wizard at: 9/29/2008 10:11 AMLast edited by: Wizard at: 9/29/2008 10:09 AM |
