(0)| 7/19/2019 1:55 PM | |
Posts: 111 Rating:
CPU226? What you are saying does not make sense. There must be other factors that is causing the compiling error. VW8000 is available for use in the CPU226. See picture below as well as attached PDF specification. Confirm this by adjusting the address from VW8000 to VW10230. Look into the usage of "configuration wizards" that might have used the address space.
Attachmentmemory-ranges-S7200.pdf (613 Downloads) |
Last edited by: AutoGen_1801304 at: 07/19/2019 13:55:57Last edited by: AutoGen_1801304 at: 07/19/2019 13:56:19 |
| 7/19/2019 2:49 PM | |
Posts: 4620 Rating:
Hello, I think depends how old is the CPU please post the code of your CPU 6es7 216-xxxxxx-xxxx Attachmentdoc_s7_200_quick_reference_info_en.pdf (619 Downloads) |
Last edited by: Ste39 at: 07/19/2019 15:10:12Last edited by: Jen_Moderator at: 07/22/2019 07:47:35Added PDF as an attachment. |
