(0)| 5/30/2020 7:40 PM | |
Posts: 1 Rating:
Can any one help me at scaling analogue signal input at S7-224 XP PLC at simulator?? I used prepared library called S_ITR but it didn't give me out put at the simulator so can any one can tell me the reason??? ------------------------------------------------------------------------------------------ |
Last edited by: Romioo at: 05/30/2020 19:49:21Last edited by: Jen_Moderator at: 06/02/2020 06:24:58New subject after splitting |
| 5/30/2020 10:14 PM | |
Joined: 9/27/2006 Last visit: 1/2/2026 Posts: 12479 Rating:
Hello Romioo; There are 2 possible issues here, since S_ITR (scale integer to real) is a standard scaling function proposed by Siemens. https://support.industry.siemens.com/cs/ww/en/view/27043396 1- the output of the S_ITR function does not provide an expected (in range) value for your program. Have you used a Status Chart to track the output of the S_ITR and check the results? 2- your simulator is not working as you expected, or you are not connected to it properly. What is the simulator you are working with? Siemens never did propose a simulator for the S7-200, and none of the ones that I tried from the web ever produced clear results. Can you provide screenshots on how your simulator reads the output of your S_ITR? Hope this helps, Daniel Chartier |
