1/19/2022 12:08 PM | |
Joined: 7/9/2015 Last visit: 11/19/2024 Posts: 4028 Rating: (603)
Hi, use FW 2.8 in TIA V16. Also check this: How do you load the project data if the version of the firmware installed in the S7-1500 CPU cannot be selected in the hardware catalog of your version of STEP 7 (TIA Portal)?Regards, Towome |
Joined: 3/5/2014 Last visit: 8/5/2022 Posts: 5521 Rating: (1054)
hi Bizz, FW 2.9 is only available in V17. Have a look to the FW-update-notes: Firmware update S7-1500 CPUs incl. Displays and ET 200 CPUs (ET 200SP, ET 200pro)You can project one of the predecessors. They will run compatible. You will just get a message in the online diagnostic that there are differences. hope this helps, regards, |
FCK WAR! |
