2/1/2023 9:55 PM | |
Joined: 9/21/2012 Last visit: 4/24/2024 Posts: 3916 Rating: (444) |
Select PN_IO as the connection network. |
2/2/2023 6:56 AM | |
Joined: 7/9/2015 Last visit: 4/24/2024 Posts: 3812 Rating: (554)
Hi, please also check the following FAQ - there you find settings for PLCSIM (i.E. Page 13). Testing and simulating HMI projects (TIA Portal) in conjunction with SIMATIC controllers, PLCSIM and PLCSIM AdvancedRegards, Towome |
2/3/2023 6:54 AM | |
PG-PC interface, what is the access point for S7ONLINE? It should be PLCSIM.TCPIP.1 in your case. |
2/3/2023 6:56 AM | |
Hi, do have a real PLC to test? Perhaps it´s an interface problem and driver don´t work well anymore. So you can try to install PC Identifier to repair it. PLC Identifier you get here: SIMATIC S7-PLCSIM AdvancedRegards, Towome |
