6/17/2023 3:22 PM | |
Joined: 9/27/2006 Last visit: 7/23/2024 Posts: 12270 Rating: (2676)
Hello Muhammad; Here is a listing of every certificate available on the Siemens SIOS for the 6ES7-331-7KF02-0AB0: https://sieportal.siemens.com/su/biWRk There is no mention of a "material test" certificate, maybe you can locate what you are looking for, under another designation.Can you tell us more about this certificat,e eiher the name of the certifying body that genrates it, or the standard it is associated with? You can try the same search with any Siemens PLC module by copying the part number in the search bar in the results page. If you cannot find what you need here, your best option is to request the particular certificate from Siemens techs, using a Support request. Open the Support link at the top of this page, then Create Support Request. Hope this helps, Daniel Chartier |
Last edited by: dchartier at: 06/17/2023 20:13:52Last edited by: dchartier at: 06/17/2023 20:53:15 |
