6/5/2024 4:53 AM | |
Joined: 1/21/2013 Last visit: 7/12/2024 Posts: 2975 Rating:
Hi, What you are asking for is the certificate for the web server. As you may already know, you must use HTTPS to access the WinCC Unified web server. This is because the communication between the web server and the web browser is protected by SSL encryption. In the WinCC Unified Configuration you have to configure the certificate to be used for this purpose. Kind regards |
6/18/2024 6:55 AM | |
Joined: 8/3/2009 Last visit: 7/12/2024 Posts: 13284 Rating:
Hello Here you find also a few information how to set up your Unified PC Station or Simulation: https://support.industry.siemens.com/cs/de/en/view/109806850 Bye Murof |
