7/10/2024 5:48 PM | |
Joined: 8/12/2021 Last visit: 7/24/2024 Posts: 322 Rating:
Hi! As you mention, Tia portal cannot see the status of the station. It is possible that the equipment is not connected correctly and it detects that a station is configured in the program that is not detected in the wiring. I would try to check this point.
