(0)| 3/25/2025 12:32 PM | |
Joined: 8/12/2021 Last visit: 12/10/2025 Posts: 351 Rating:
Hi! It's difficult to diagnose a communication problem with the information provided. I understand you're working with an Ethernet/IP adapter, correct? If you're using an S7-1500, Siemens has libraries for switching from RJ45 to Ethernet/IP. You may be able to use them as a substitute (Scanner and Adapter). |
