(0)| 12/9/2011 10:07 AM | |
Posts: 329 Rating:
Dear, I faced the same problem with old Moller drive and i got over the problem by little reduce field by 25%. you could try? Regards, |
| 12/9/2011 10:20 AM | |
Posts: 8092 Rating:
In this case field is fixed full wave diode rectifier bridge. As such could not adjust any field voltage or current parameter. |
| 12/9/2011 3:56 PM | |
Posts: 329 Rating:
Dear, if no way to reduce field voltage or current you can add any transformer with reducing factor it also so usefull to reduce field. Regards, |
