Industry Online Support
5/25/2007 4:52 PM | |
Posts: 328 Rating:
Dear Sir The connection and operation of your 1FK motor to S7 via 611U on profibus is not a simple task. I would suggest havng a look at the following link to start with. The give our Turkish Office a call, Im sure they can help you further. You will need to parameterise the 611U using Simocom U software.Then setup coms to the PLC, you will need a profibus module for the 611U https://www.automation.siemens.com/doconweb/content.asp?item=23031&cd=sinumerik_0107_e&scope=all best regards SteveJ |
