Industry Online Support
9/18/2013 7:24 AM | |
Joined: 1/28/2009 Last visit: 8/5/2024 Posts: 6844 Rating: (1365)
Hello, That is possible easily in SCL.In case of using STL, you have a small problem of calculating physical address of cell in the array.I can suggest checking the following topic and see the contrast: Arrays, DB and pointersBest regards Hamid Hosseini |
7/6/2014 11:41 AM | |
Posts: 101 Rating: (0) |
hello Yeltsin Munive your ilustration about what you need is not so clear.if you put example or snapshots it will may help us to help you. ..................................... mohamed elokby
7/7/2014 2:34 PM | |
Joined: 3/25/2013 Last visit: 3/21/2019 Posts: 176 Rating: (1) |
New question split intohow can I introduce the data from a measuring device to a Data Block. With best regards, Narrator1
