10/18/2016 10:54 AM | |
Posts: 6 Rating: (0) |
Hi guys, I am trying to get connection between a PLCSIM and NetToPLCsim but it does not run. The thing is that I set network as: IP PG = 192.168.92.32 / Submask: 255.255.252.0 / Gateway: 192.168.92.30 IP PLC SIM= 192.168.92.40 (same range PG) / Submask: 255.255.252.0/ Gateway: 192.168.92.30 When everything is set up and running, I make a ping to the PLC IP, but it does not working. I am still thinking about if I did a wrong step. Attached you may find more clearly the situation I am talking about. Anyone could give a solution with this issue? Thank you in advance ------------------------------------------------------------------------------------------ Attachmentplc to netToPLcsim.pdf (852 Downloads) |
Last edited by: Min_Moderator at: 10/18/2016 4:08:28 PMNew subject after splitting |
