(0)| 2/27/2006 9:27 PM | |
Posts: 21 Rating:
Hello, How do I download files stored on a compact flash memory with Ethernet since a PC ? Thank you Bye |
| 2/28/2006 10:34 AM | |
Posts: 3149 Rating:
Hi Zoax, unfortunately I couldn´t locate your problem, but perhaps these FAQ will answer some of your questions: http://support.automation.siemens.com/WW/view/en/22700159 http://support.automation.siemens.com/WW/view/en/19348162 http://support.automation.siemens.com/WW/view/en/21848668 nemo |
| 3/1/2006 12:35 PM | |
Posts: 3149 Rating:
Hi Zoax, perhaps Active Sync can solve your problem: http://support.automation.siemens.com/WW/view/en/12933294 http://support.automation.siemens.com/WW/view/en/13336639 http://support.automation.siemens.com/WW/view/en/15250466 If you are using WinCC flexible you can use the option Sm@rtaccess nemo |
