2/28/2019 4:52 AM | |
Posts: 4 Rating:
Good day. I have a problem with r 120 qyu 240. after starting the pump motor. When stopped after work for about 20 minutes, an error 3001 (overcurrent) occurs, the engine immediately turns off abruptly. And when you stop after work for 5 minutes, it stops normally. Why is this happening. Regards, Ilya Abramov Original text Добрый день. У меня проблема с Г 120 ЦЮ 240. после запуска двигателя насоса. При остановке после работы около 20 минут возникает ошибка 3001( перегрузка по току) двигатель сразу отключается резко. А при остановке после работы в течении 5 минут нормально останавливается. Почему это происходит. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 2/28/2019 6:39:17 AMNew subject after splitting |
2/28/2019 6:40 AM | |
Joined: 6/19/2017 Last visit: 6/28/2024 Posts: 8176 Rating:
Closed cause question posted twice. The second thread with the subject Error 3001 (overcurrent) occurs - the engine immediately turns off abruptly. is published within the conference SINAMICS. Best regards Jen_Moderator |
