8/13/2019 2:58 PM | |
Posts: 5 Rating: (0) |
is there documentation or some sort of walkthrough on how to connect WinCC v7.5 via the cloud connector to Microsoft Azure? |
8/13/2019 6:23 PM | |
Joined: 9/19/2009 Last visit: 7/5/2024 Posts: 459 Rating: (84) |
Hi This sample isn´t for Microsoft Azure, but maybe can help you. Regards Attachment109760955_WinCCCloudConnector_en.pdf (108 Downloads) |
Last edited by: Jen_Moderator at: 08/14/2019 09:09:15Added PDF as an attachment. If my answer help you, use the Thanks or Rate Button, It is free of charge :-) |
8/28/2019 9:57 AM | |
Joined: 12/12/2011 Last visit: 12/30/2020 Posts: 821 Rating: (41)
Hi, the shown application example is for AWS. If you need help with your application for Azure, you should contact the technical support: https://support.industry.siemens.com/cs/ww/en/sc/2090 B.R. |
Grundkurs/Systemkurs WinCC V7: |
