9/30/2014 6:29 AM | |
Posts: 37 Rating: (3) |
You ned an analog output module. EM232(2 analog output) or EM235 (4 input/ 1 output).And for some help: What HMI do you use?
10/2/2014 4:12 PM | |
Joined: 7/29/2014 Last visit: 7/30/2024 Posts: 82 Rating: (0) |
I am using a MP377. Though, I have four EM-231 units. I can't use the PLC itself? One of the outputs within it? |
10/15/2014 8:50 PM | |
Joined: 12/13/2013 Last visit: 10/7/2024 Posts: 135 Rating: (3) |
HI! SagarDPatel even though i am also fresh for plc worled, i have attached my program how i handele the same case to control pressure sensor. the main thing you have to know is your variable that you are asigning value should be plc tag not local hmi tag. |
We Keep Your Plant Running |
