Industry Online Support
6/4/2009 7:48 AM | |
Posts: 78 Rating:
Hello, |
6/4/2009 7:51 AM | |
Joined: 5/12/2006 Last visit: 7/15/2024 Posts: 22308 Rating:
Hello, which IPO cycle? Regards Christoph |
6/4/2009 8:00 AM | |
Posts: 78 Rating:
Ipo cycle and ipo2 cycleare default value. |
6/4/2009 8:05 AM | |
Posts: 116 Rating:
Hi, there is a missing information: DP = 2 ms Servo = 2 ms IPO = ??? But even if you use a much higher IPO, D435 won't fit. Use the new D445-1 (higher performance than D445 and same price) You can estimate SIMOTION cycle times with SIZER! see https://mall.automation.siemens.com/DE/guest/index.asp?aktprim=0&lang=en&nodeID=10018084&foldersopen=-1329-2-1271-1273-&jumpto=1273 Regards Jerry |
6/4/2009 8:16 AM | |
Posts: 78 Rating:
Hello, ChrisophD As your word , DP=4 Serve = 4 ipo = 8 ipo = 18 what be bad influence for the Simotion D system ? For example: lower percision? |
