3/16/2020 9:15 PM | |
Joined: 4/28/2015 Last visit: 10/20/2023 Posts: 43 Rating:
Hi cinuco, jacek d is correct. You need to share the load amongst both drives. Otherwise they will eventually work against each other. For more information see chapter 1.1 in SINAMICS S: DCC Load Sharing! V90 supports telegram 750. You could use MC_TorqueAdditive to add the delta of your master motor torque setpoint to your slave motor. MC_TorqueAdditive.Value := <Master>.StatusTorqueData.ActualTorque - <Slave>.StatusTorqueData.ActualTorque; |
Last edited by: Jen_Moderator at: 03/17/2020 05:32:40Optimized links. Grüße, Axel |
