11/26/2008 9:28 PM | |
Posts: 1064 Rating: (72) |
do you jave broken wire detection enabled in the haedware configuration or do you have the 24 power supply connected with out the inputsn connected maybe this will help http://www.jlab.org/accel/ssg/12gev/PSS/manuals/S7%20300F%20FailSafe%20Signal%20Modules_e.pdf Steve |
12/3/2008 10:09 PM | |
Posts: 3 Rating: (0) |
I deactivated everything that is possible to deactivate. I have port 22 and 23 connected for power supply. I tried connecting 22 with 30, but no change. The SF lamp is led... I am out of ideas…it should not be lit while the channels are deactivated. I attach some screen dumps. Attachment081203.zip (133 Downloads) |
12/4/2008 1:37 PM | |
Thank you fot the tip, but unfortunately the "enable diagnostic interrupt" box has not been checked. So I m afraid thats not the problem Best regards |
