Industry Online Support
6/1/2009 5:15 PM | |
Joined: 5/28/2008 Last visit: 11/6/2024 Posts: 4516 Rating: (839) |
Hello, For sellection purpose, please try using configurator in this link. ETU is an expression for the electronic trip unit of the MCCB. Each CB has tripping curve and if you select ETU10 , it has curve different of ETU20 for the same CB size. From here, you can understand why you found large varieties of MCCB for the same current, size and short circuit level. But finally, if you use the configurator, and if you entered the data of your application correctlly, it will finally gives you the suitable part number and also dimensional drawings and isometric or 3-D files for the breaker selected. With best regards, |
Ayman Elotaify |
