3/27/2008 1:58 PM | |
Posts: 3 Rating: (0) |
Hi everyone, is it good toconnect S7-200+EM231 and analog 4-20mA sensor to one (the same)"SITOP" power supply? Thanks |
3/27/2008 2:15 PM | |
Posts: 2930 Rating: (432)
Hi, if the power supply is able to power all the units then it should not be a problem. Regards Helmut |
3/27/2008 2:31 PM | |
Posts: 264 Rating: (59) |
Hello, You should use a glass tube fuse for your sensor, especial when you´re afraid of a sensore failure! best regards... |
3/27/2008 3:19 PM | |
I made conetion like this: Is it right? Attachmentconnection.pdf (277 Downloads) |
3/28/2008 8:30 AM | |
Yes I founded scaling program in the forum. Thanks for suggestions. |
