6/25/2010 1:05 AM | |
Joined: 3/26/2009 Last visit: 2/3/2022 Posts: 43 Rating:
Which logo are you using? Fred(Derf) |
6/25/2010 7:30 AM | |
Joined: 6/24/2010 Last visit: 12/7/2021 Posts: 21 Rating:
Hi Fred, I am using a 0BA6 24v with a DM16 and a AM2 AQ. Thanks, Richard |
6/25/2010 8:03 AM | |
Posts: 153 Rating:
Greetings Donkey. At a forum there was a theme connected with binary inputs / outputs. I have only a program code. And your problem is not much another. You could is more more detailed describe about an analogue output Attachmentdecimal to binary Converter.zip (523 Downloads) |
6/25/2010 10:14 AM | |
Posts: 661 Rating:
Hi there, please find attached a program i made some time ago for LOGO! 0BA5. Maybe this is what you need. Regards Fux Attachment4-Bit DA-Converter.zip (517 Downloads) |
6/25/2010 10:32 AM | |
Posts: 173 Rating:
Sounds like a BCD (4 bit) to decimal converter. Maybe look under this as a search topic. Cheers Aaaaarrrgghhhh! ("Have a nice day!") |
6/25/2010 10:37 AM | |
Joined: 3/4/2009 Last visit: 10/28/2020 Posts: 57 Rating:
Hi. Have a look at the attached program.I made it in rush. You can find a better solution or improve the program. But i hope you find it helpful. Attachmentdig in analog out.zip (437 Downloads) |
2 thankful Users |
6/25/2010 10:41 AM | |
Posts: 661 Rating:
If you can use a LOGO! 0BA6, then it´s possible with less function blocks by using analog arithmetic:
Attachment4-Bit DA-Converter_0BA6.zip (431 Downloads) |
Last edited by: Fux at: 6/25/2010 10:44 AMIf you enable all inputs the message text will display 15V, but physically the maximum output voltage will be 10 V of course. |
4 thankful Users |
6/25/2010 12:20 PM | |
Posts: 173 Rating:
What a great elegant solution! Thanks! Aaaaaarrrrggghhh!!! ("Have a nice day!") |
6/25/2010 2:11 PM | |
Posts: 661 Rating:
Hey LOGO!Barbarian, what a great new avatar |
