6/23/2013 9:18 AM | |
Joined: 12/27/2006 Last visit: 8/18/2024 Posts: 1197 Rating: (113) |
Can anyone help me on the way. Can anybody give me a hint (or a programm) to make this carousel switch? Attachment4_Compres.zip (551 Downloads) |
6/23/2013 4:20 PM | |
Joined: 6/15/2012 Last visit: 3/26/2024 Posts: 2 Rating: (0) |
Hi, it is possible to use the shif registry. |
6/24/2013 11:26 AM | |
Joined: 11/23/2011 Last visit: 9/30/2024 Posts: 202 Rating: (32)
Hello Toeternietoe, please have a look on the following completed solution examples. https://www.automation.siemens.com/mcms/programmable-logic-controller/en/logic-module-logo/application-examples/Pages/Default.aspx?HTTPS=REDIR Maybe you will find there some helpful ideasor a solution for your case. Greetings, KM_AS |
6/26/2013 8:43 PM | |
Joined: 1/5/2007 Last visit: 4/7/2023 Posts: 1690 Rating: (580)
Hello Toeternietoe, from the answers before you get some ideas... Look the file "DEMO_Up_down_step_controller (0BA5).lsc" at the attachment to get a solution of your question - it use the chronological order of the outputs to controll them... If you need to use the working time of the compressors (to compensate different working times) the other file give you an opinion to solve that - of cause it is only for 3 outputs, but you can modifiy this... Best regards AttachmentDEMO_Up_down_step_controller (0BA5).zip (481 Downloads) |
6/27/2013 9:35 PM | |
Hello Toeternietoe, in addition to my answer yesterday and to controll my circuit "DEMO_Up_down_step_controller (0BA5).lsc" with the aim of your cirkuit "4_Compres.lsc" i present you my circuit The combination of both is the file "DEMO_Up_down_solution_V1 (0BA5).lsc". I am not sure, but maybe it can give contitions witch results a wrong number of active outputs? So i have build an other version of controlling the outputs ---> File "DEMO_Up_down_solution_V2 (0BA5).lsc"...Now the number of active threshold triggers are equal to the number of active outputs. Best regards AttachmentDEMO_Up_down_step_controller (0BA5).zip (517 Downloads) |
3/15/2017 11:21 AM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4766 Rating: (122) |
New question published by norimane is split to a separate thread with the subject Program to manage 5 Compressors. Best regards |
