2/23/2022 3:14 PM | |
Joined: 12/13/2013 Last visit: 5/17/2024 Posts: 135 Rating: (3) |
dear dchartier i have attached the Diagnostics buffer in txt as you requested. but to try" you should create OB 122 in the Blocks folder of Step 7 and download it to the CPU" this i am currently using TIA portal V16 and this CPU is not supported by My Engineering Software . Please Advice me if there is any possibility to do so using TIA or any other options. Thank you for supporting AttachmentDiagnostics bufer.txt (364 Downloads) |
We Keep Your Plant Running |
