8/30/2023 6:20 PM | |
Joined: 3/28/2015 Last visit: 5/10/2024 Posts: 721 Rating: (213) |
Hello, 6ES7510-1DK03-0AB0 Engineering with
● STEP 7 TIA Portal configurable/integrated from version V18 (FW V3.0); with older TIA Portal versions configurable as 6ES7510-1DJ01-
0AB0 Attachment6ES75101DK030AB0_datasheet.pdf (726 Downloads) |
Eng.Mohamed Ibrahim |
8/31/2023 5:49 AM | |
Joined: 1/21/2013 Last visit: 5/10/2024 Posts: 2765 Rating: (448)
Hi Tarv, According to the delivery release note, it should be possible to configure and load as a predecessor version. Maybe the FAQ "How do you load the project data if the version of the firmware installed in the S7-1500 CPU cannot be selected in the hardware catalog of your version of STEP 7 (TIA Portal)?" will help you. Kind regards |
