3/31/2020 11:54 AM | |
Joined: 5/30/2018 Last visit: 10/13/2023 Posts: 2 Rating:
Hi Ste39. Thanks For this link but I still can not load the correct part from the hardware catalog see attached Screen shot. I'm trying to add 6ES7155-6AU01-0CN0 I can only see the previous item. Thanks Jamie
10/9/2020 1:43 PM | |
Posts: 5 Rating:
Hi, Is this problem got resolved? Even I am facing the same problem after installing the GSDs also, I cannot load the new module into my project. |
10/9/2020 2:10 PM | |
Joined: 9/21/2012 Last visit: 6/30/2024 Posts: 3985 Rating:
If you take a look at the module Datasheet, what does it tell you? You can't find the part number from the Hardware catalog? Or you can't install the GSD file? |
10/9/2020 4:19 PM | |
Joined: 9/27/2006 Last visit: 6/30/2024 Posts: 12264 Rating:
Hello Saha; Actually, it would be better with TIA Portal v15.1... Hope this helps, Daniel Chartier |
10/30/2020 10:02 AM | |
Posts: 5 Rating:
Hi, Thanks for your answer. Do I need a safety license also if I want to migrate the project from TIA 14 to TIA15.1? |
