7/1/2019 2:37 PM | |
Joined: 9/27/2006 Last visit: 11/4/2024 Posts: 12293 Rating: (2690) |
Hello Homolamatus; Your CPU 317F-2PN/DP already has a Profibus-DP interface, see your screenshot. If the idea was to simply connect the MP 377 to this CPU ( unless this was an experiment on gateway configuration), you could use that Profibus interface directly, without a IE/PB link as a gateway. This FAQ would be quite informative: How do you configure a connection between WinCC flexible Runtime (PC/Panel) and a SIMATIC S7-300/S7400 via PROFIBUS/MPI? https://support.industry.siemens.com/cs/us/en/view/42918861 Use the sections marked as "Connecting a panel" in the linked document to setup your configuration. Hope this helps, Daniel Chartier |
12/13/2019 8:56 AM | |
Joined: 2/8/2011 Last visit: 9/7/2023 Posts: 87 Rating: (8) |
Dear Homolamatus, Yes, you can use that equipment but before selecting that please read the document because you should create PN and DP side telegram. Use a DB for communication read and one more DB for write... Please check this link for your equipment document https://support.industry.siemens.com/cs/gb/en/view/109744280 |
