Industry Online Support
5/2/2009 8:44 AM | |
Joined: 3/21/2006 Last visit: 4/25/2024 Posts: 10228 Rating:
Hello, The SIMOREG K 6RA24 is connected to the PROFIBUS-DP via the communications board CB24. It supports baud rates up to 1.5 Mbit. Order no.: CB24: 6RX1 240-0AK01. GSD file SIMOREG_6RA24.ZIP For this purpose you'll need to add to he S7-300 CPU - CP340. Look at
More info about CP340 in manual - PtP coupling and configuration of CP 340 Hope this will helps. Best regards Hristo Mihalev |
5/4/2009 2:55 PM | |
Posts: 102 Rating:
Hi, Thank you UMENCHO. I will look the zip file. And if possible I will go ahead with Profibus card option. with regards, Dutta |
5/15/2015 11:13 AM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4770 Rating:
