2/21/2018 4:56 AM | |
Joined: 4/23/2010 Last visit: 12/31/2023 Posts: 8092 Rating: (872) |
Hello, F005 = Fault in field circuit. Have you studied fault value of fault F005 whenever this fault has triggered? Is the fault value same or most of time same? Which is fault value you found most of the time same? You can check fault value in r0949 indices. Please refer the attached sheet expalining the significance of fault values in F005. HTH. Attachment6RA70 F005 fault values.pdf (345 Downloads) |
