9/22/2021 7:59 PM | |
Posts: 1 Rating: (0) |
I have a problem with 6SN11-1BA02-0CA2 it is worked normally for two to 6 hours then LED 5 lit ( Line supply fault) I check ed power supply carefully and I found it is ok and inside I did not get anything loose. I replaced it with another one ( spare one ) and it is worked normally on the same machine. what can I do to solve this problem of this drive? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 09/23/2021 09:42:58New subject after splitting |
9/23/2021 7:32 PM | |
Joined: 10/17/2007 Last visit: 5/12/2024 Posts: 3985 Rating: (342)
Very simple ---it is defective, send it to Siemens or Siemens contractor to repair. I can repair it as well if you like you can send it to me
If you like my comments please |
