5/28/2019 8:50 AM | |
Joined: 3/12/2015 Last visit: 5/16/2024 Posts: 533 Rating:
5/29/2019 2:33 PM | |
Joined: 1/19/2008 Last visit: 7/3/2024 Posts: 987 Rating:
Hi The baud rates must match and you will probably need to drop to 300. It will take a lot longer but should work. Pee |
6/7/2019 11:36 AM | |
Does anyone know what parameters i would have to change on the 810 control to lower the baud? The tea1 file dosent transfer the tea2 does transfer. tea1 starts then stops but the tea2 starts then finishes without stopping and i can see when im transfering the tea2 file TEA2 on the cnc screen AttachmentTEA1.txt (137 Downloads) |
6/7/2019 1:24 PM | |
Joined: 11/26/2016 Last visit: 10/8/2023 Posts: 138 Rating:
Dear sir; Your TEA1 file seems to be valid. I attached a small pdf for setting the serial baud rate on your machine, I followed this before and it works well. Now you have to 1- decrease the baud rate, and take care that PCIN serial parameters agree with your machine parameter(you can send me pictures to check if you want). 2-change your cable or check it. 3- clear your NC data, and follow that attached procedure for loading. I wait for the result. Good by. Attachment810_820 reload.pdf (174 Downloads) |
Nothing IS IMPOSSIBLE. |
6/7/2019 1:25 PM | |
Serial baud rate adjustment page#1 attachments. AttachmentSerial Baud rate adjustement-1.pdf (183 Downloads) |
6/7/2019 1:26 PM | |
Serial baud rate adjustment page#2 attachments.
AttachmentSerial Baud rate adjustement-2.pdf (140 Downloads) |
