10/18/2023 10:12 AM | |
Joined: 7/16/2019 Last visit: 4/22/2024 Posts: 16 Rating:
Hello, We want to add a 4th-axis to a machine with 828D controller, software V4.4 SP4. When we check the topology, we find that the machine was configured with a 4th-axis from the OEM factory. When we connect our 4th-axis (Drive and motor) to the machine, the alarm "201420 Topology: Component different" is triggered. We want to delete the old 4th-axis and add & assign the new one. Problem: To delete a drive object, we need to use the drive parameter p09=112 and p9912. Please see the attached pictures. Could you please provide a solution to install the 4th-axis. Kind regards, AttachmentTopology and p9 missing.zip (169 Downloads) |
kind regards |
10/19/2023 5:04 AM | |
Hello, From the attached snap already your machine configuration is of 4 axes i.e. spindle+X+Y+Z. Please check. |
