9/15/2016 4:59 PM | |
Posts: 13 Rating: (0) |
Hello, I've got a 828D 3 axis (with a X gantry axis) I tried to increase the offset , amplitude and average but no way... the message is already the same : "The phase of the measured FRF as low frequency behavior that significantly deviates from the dynamics model. Corrective action : Experiment with offset and excitation". So I can't achieve the motor tuning. Can you help me ? Which measure parameter should I modify to avoid this problem ? Thnak you very much. Pierre. ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 9/16/2016 1:24:15 PMNew subject after splitting |
