7/10/2023 8:10 PM | |
Joined: 7/10/2023 Last visit: 7/11/2023 Posts: 4 Rating:
If I insert a USB drive, the button is highlighted and works. Others don't. |
7/11/2023 8:50 AM | |
The basesys.ini file only exists in "/card/user/system/etc" The folder card/siemens/system/etc/ and oem is empty.... I don't have template files. I'm adding a basesys.ini file that exists. Thank you. Attachmentbasesys.txt (276 Downloads) |
7/11/2023 11:39 AM | |
Joined: 5/24/2016 Last visit: 7/16/2024 Posts: 339 Rating:
I was not referring to the dots. But to the slash amount before you're IP adresse. It should not be / but // |
