12/12/2012 9:28 AM | |
Joined: 12/4/2012 Last visit: 1/14/2022 Posts: 8 Rating: (0) |
Hello, nobody knows what should be the problem? Is there any special keyboard required? Thanks Jiri
12/12/2012 9:58 AM | |
Joined: 4/23/2010 Last visit: 12/31/2023 Posts: 8092 Rating: (872) |
Can you provide the MLFB number of original faulty kep board? |
12/12/2012 1:26 PM | |
Hello, The MLFB number provided by you is of MMC s/w. Please have a look at attached sheet. Does your system configuration looks like it? If so you may find the MLFB number on stickerpasted on the rear side of key board. Hope this may help you. AttachmentKeyboard problem.pdf (90 Downloads) |
12/13/2012 7:01 AM | |
Hello, The other keyboards which you tried are those AT compitable? Please check the pin connector of original defective & the others which you tried. For more information, please see the attached sheet. AttachmentMMC 102 keyboard interface.pdf (81 Downloads) |
12/13/2012 9:22 AM | |
No. Only one can be connected. Either key board or mouse. |
