2/8/2012 3:08 PM | |
Posts: 101 Rating: (8) |
Providing you have the correct com port set up and matching baud rates you should be fine but Some USB - serial adapters just do not work with drivemonitor no matter what you do. The attached contains some tried and tested adapters which are recommended. AttachmentUSB_RS232_Adapter_en_V1_2.pdf (702 Downloads) |
