4/12/2011 7:34 AM | |
Posts: 21 Rating:
A PT100 is NOT a temperature dependent resistor ! |
4/12/2011 7:45 AM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating:
Here you can find a resistance table http://marelsys.blogspot.com/2009/05/pt-100-resistance-table.html all PT100 are the same (within 4%), measure -200 to 850 degrees and have a resistance of 100 ohm at Attachmentlogo_pt100.pdf (525 Downloads) |
Last edited by: Marcjan at: 4/13/2011 11:46 AMeddit mistake Last edited by: Marcjan at: 4/13/2011 7:14 AMLast edited by: Marcjan at: 4/12/2011 8:12 AMattached wiring diagram Problem solved? |
4/12/2011 9:55 PM | |
Joined: 12/27/2006 Last visit: 7/7/2024 Posts: 1197 Rating:
You must use a AM2-PT100 Module ordernr: 6ED1055-1MD00-0BA0 But.... it works from -50 to + 200 degrees C |
