2/1/2017 2:09 PM | |
Posts: 71 Rating:
Hi everyone, I'd like to share a node-red node with you that enables you to:
To install, unzip the attached archive and copy the contained directory to '/usr/lib/node_modules/node-red/nodes'. You will then have two new nodes available in node-red:
Attachmentnode-red-contrib-iot2000-gpio.zip (2435 Downloads) |
13 thankful Users |
2/17/2017 8:44 AM | |
Posts: 71 Rating:
Behind the left cap. The pinout is Arduino-compatible so just have a look at the Arduino (Uno) pinout. It depends on the way you are interfacing the IOs. Have a look at the mraa library example programs: https://github.com/intel-iot-devkit/mraa/tree/master/examples |
3/3/2017 12:04 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4770 Rating:
New question published by JDarius is split to a separate thread with the subject How can I detect a falling edge on the User button?. Best regards |
5/2/2017 10:48 AM | |
New question published by anjalirani is split to a separate thread with the subject Read a sensor value sing analog pin A0 of Arduino with python. Best regards |
