7/4/2006 10:56 AM | |
Joined: 4/24/2006 Last visit: 7/12/2024 Posts: 8711 Rating:
Hello Coil, There are a lot of known problems with CP5511, ![]() did you see the following link: http://support.automation.siemens.com/WW/view/en/12259435 This will also be very helpfull: http://support.automation.siemens.com/WW/view/en/19279714 http://support.automation.siemens.com/WW/view/en/19701396 http://support.automation.siemens.com/WW/view/en/9853739 I hope this will help to let the CP5511 function. If this is not a remedy, then You should consider to buy a CP5512 ![]() Best regards, Wizard |
