4/8/2024 5:31 PM | |
Joined: 9/8/2011 Last visit: 6/6/2024 Posts: 537 Rating:
You need a VPN. There are many on the market. You put the VPN on the network with the PLC. After to you have your account set up and it logs into the cloud, You run software on the your computer to attach to the cloud - And it gives your PC an address on that PLC network. Then the PLC software can access the PLC through your "tunnel". https://cdn.automationdirect.com/static/catalog/images/product-pdf/STL-stridelinxvpnrouter.pdf https://media.hms-networks.com/image/upload/v1705053547/Documents/Brochures/Ewon_Brochure_Cosy%2B_EN.pdf |
A smart person learns from their mistakes |
4/9/2024 1:50 PM | |
Joined: 8/3/2009 Last visit: 7/9/2024 Posts: 13244 Rating:
Hello mesra4444 there are also some Informaton from Siemens available: https://support.industry.siemens.com/cs/de/en/view/26662448 Bye Murof |
