2/7/2022 1:15 PM | |
Joined: 4/28/2015 Last visit: 6/3/2024 Posts: 3345 Rating:
Hi, did you see this entry? There basically the steps you have performed are described (a user posted a PDF with all the steps), but the mount command is used without the password=pa55w0rd option. As it is described the password is prompted after the command. Can you try that? Best regards! |
Not working for IOT2050 support anymore from March 1st, 2024. |
2/9/2022 1:56 PM | |
Hi, for me it works! Steps I did on the IOT2040:
Steps I did on Windows 10:
I was then able to mount the folder with:
After issuing the command I was prompted for the password. Best regards! |
