6/25/2009 1:40 PM | |
Joined: 4/24/2006 Last visit: 5/8/2024 Posts: 8638 Rating: (1151) |
Dear dzwilu, When using WinCC: Please have a look at this faq: http://support.automation.siemens.com/WW/view/en/25430568 Or when using WinCC flexible: Just configure an internal tag - string data type. Use the scheduler to create a job that uses the 'Get User name' function on Change User event. Put an I/O field on the screen and attach the string tag. Best regards, Wizard |
6/25/2009 1:49 PM | |
Posts: 261 Rating: (42) |
Hi, You can try this attached pdl. regards ddg Attachmentusername.zip (403 Downloads) |
6/26/2009 12:23 PM | |
Joined: 12/3/2008 Last visit: 3/22/2022 Posts: 146 Rating: (4) |
Hi, i'm using WinCC flexible, didn't know about the change user event Problem solved - Thanks! Best regards dzwilu |
