3/25/2019 12:34 PM | |
Joined: 4/28/2015 Last visit: 6/3/2024 Posts: 3345 Rating: (379)
Hi, here is an example image about shared libraries. In the documentation in chaper 3.3 you can see how to link them. I am not sure if this is the same procedure with static libraries. Best regards! |
Not working for IOT2050 support anymore from March 1st, 2024. |
3/1/2021 2:35 PM | |
Hi, here you can find an example how to add static libraries to Eclipse. This is being done on the exampe of an ODK1500S Example, but I guess the procedure should be the same. Hope that helps! Best regards! |
